We introduce the combination of COREGEN flow and LabVIEW FPGA flow to allow users write their C code applications on MicroBlazeTM processors on National Instrument FPGA based boards.
We introduce the combination of Xilinx EDK flow and LabVIEW FPGA flow to allow users write and debug their C code applications on EDK-based MicroBlazeTM processors on National Instrument R-series boards.
I have a modified version of this example running on a PXI-7854R. It makes a convinent platform to run code that has to be more tightly coupled to the FPGA than is allowed through cPCI back to a NI LV-RT controller.
Any updated version that works with later versions of the Xilinx tools?
Also, anybody out there running a TCP/IP stack such as lwIP on a MicroBlaze Processor using LabVIEW?
Awesome posting, thanks to NI Labs for releasing this.
I try to follow the steps in the link documents. For my sample, I did not use the debugger (No debug at project startup). Every time I compile the Lv VI, Xilinx returns at the end a "Timing Violation" for "40 MHz Onboard Clock", as detailed below :
40 MHz Onboard Clock: 40,41 MHz (0,41 MHz maximum)
Any idea ? Thanks for your help.
Thanks for your all interest in this. I currently have no plan to support in the shipping LabVIEW FPGA 2010 as well as Xillinx 11.5 version. However , you can email me about specific request. my email is trung.n.tran@ni.com.
Hi Jabba,
Thanks for your interest. It seems the problem may come from the clock input for the MicroBlaze system . Could you please contact me at trung.n.tran@ni.com and send me related files ( MHS files , the labVIEW project and VIs) of your system .
It seems I can't reach you through your email. Any mistake in the your mail's adress?
This posting opens up a world of possibilities for hardware/software codesign targeting NI FPGA-based boards. We just published a C/C++-based ESL flow for NI FPGA-based boards that leverages the MicroBlaze embedding capabilities presented in this posting.
Thanks for posting the link to your HW/SW codesign technology page.
ALL - I added helpful links as a comment to the page which Laurent Moss includes in his comment, above. Included is a link to a Demo and a Presentation via WebEx. Just visit the link in Laurent's comment above, and look for my comment with the additional links.
Any updates for supporting LabVIEW 2014 SP1?
I tried running the patch for LabVIEW 2013 SP1 on my LabVIEW 2014 SP1 machine and it stopped complaining about the version.
Thanks for your interest , I will update the release for 2014 SP1 soon.
I'm almost there in getting things to work with LabVIEW 2013 SP1.
I was wondering if you had the source to the Xilinx SDK project that you used? I want to make sure I am using it correctly.
Also, if you want any help updating the MicroBlaze patch, please make a repo on NI's github and I'd be very happy to join in on the fun
I got my first MicroBlaze C++ project running on the PXI-7953R board, I will write it up as nicely as I can and share it on github.com soon.
Thanks for posting this info here!
Any updates for LabVIEW 2016?
So a lot of time has passed, and I have become an expert in LabVIEW FPGA and MicroBlaze together.
Anyway, here is a github repo that uses LabVIEW FPGA, MicroBlaze and a UART to communicate:
https://github.com/JohnStratoudakis/MicroBlaze_UART
And my question is - has anybody gotten the MicroBlaze Debug Module to work from LabVIEW? I have been looking around and it seems like a lot of reading to figure this one out...
