NI Labs Discussions
Welcome to EtherNet/IP Industrial Protocol Support
I think there is a packet data limit of 500 bytes.  (118 floats x 4 bytes/float = 472 bytes)  Not sure why only 119 doesnt work but 200 is over the 500 byte limit.
Message 91 of 125
(7,212 Views)
I am deeply sorry if this question has been previously asked, but I am having a problem connecting a Keyence Ethernet/IP Device to LabVIEW using the Industrial Communications for Ethernet/IP. I have been trying to find answers on other sites all morning and have had no luck. I am just looking to read a single measurement for a digital sensor. Any help would be appreciated!
Thanks!
Message 92 of 125
(7,212 Views)
I imagine you would have to use the SLC500 Read and Write vis, not the Tag ones.
You have to know the File and Element to read.
Message 93 of 125
(7,212 Views)
Given the little picture, I do not see how the program knows the IP Address of the Ethernet/IP connection. Also, from looking in the LabVIEW help menu, it appears that this specific VI is used for PLC, of which I am not using.
Message 94 of 125
(7,212 Views)
The network path is a string which connects just above the Element.
After a quick Google search, it appears that it uses Tags, not the SLC500 vis as I had stated.
I don't know what the Tag names would be, but this video might help.
http://www.sensorcentral.com/knn/control_logix.php?section=0
Message 95 of 125
(7,212 Views)
Thank you for your reply. The video was very informative. However, I think I stumbled upon the real problem. It appears that my Ethernet/IP Communication Unit is not connecting to the network. After reading the manual, it appears that I need an Ethernet/IP Scanner and use the .EDS file to configure my device. Does anyone know of a way of just using a PC to configure the DL-EP1?
Many Thanks
Message 96 of 125
(7,212 Views)
