02-03-2012 07:56 AM
The debug version does not install anything at all. The dialog is wrong. It simply creates a text file on your desktop with debug information. Can you attach that text file to this thread so I can look?
02-05-2012 06:59 PM
For your information I attached the log anyway.
Thank you very much for your time and effort!
yelingxing
2011
C:\Program Files\National Instruments\LabVIEW 2011
C:\Users\chenmuyuan\Desktop\NI VeriStand FPGA Interface Tools 2010+ 1.1.1\NI VeriStand FPGA Interface Tools 2010+\Files\2010
resource
Targets
user.lib
C:\Users\chenmuyuan\Desktop\NI VeriStand FPGA Interface Tools 2010+ 1.1.1\NI VeriStand FPGA Interface Tools 2010+\Files\2010\resource
C:\Users\chenmuyuan\Desktop\NI VeriStand FPGA Interface Tools 2010+ 1.1.1\NI VeriStand FPGA Interface Tools 2010+\Files\2010\Targets
C:\Users\chenmuyuan\Desktop\NI VeriStand FPGA Interface Tools 2010+ 1.1.1\NI VeriStand FPGA Interface Tools 2010+\Files\2010\user.lib
C:\Users\chenmuyuan\Desktop\NI VeriStand FPGA Interface Tools 2010+ 1.1.1\NI VeriStand FPGA Interface Tools 2010+\Files\2011
03-14-2012 11:25 AM
Hello Stephen,
I want to report a bug about Ni 9217 RTD module Ni Veristand FPGA Library. XML example has bug in 9217 4Ch RTD Input.vi
</Parameters> is missing. Because of that Veristand gets an error.
Best Regards,
03-15-2012 10:01 AM
Fixed! Thank you for letting me know
04-25-2012 10:30 AM
Hi Stephen,
I get the same error as Tobias and yelingxing... I am using Labview 2011 SP1 and Windows XP.
I used the NI VeriStand FPGA Interface Tools Installer_DEBUG.vi, and you can find attached the log file I get.
Maxime
2011
D:\Documents and Settings\mderbois-ext\Mes documents\Téléchargements\NI VeriStand FPGA Interface Tools 2010+\Files\2010
resource
Targets
user.lib
D:\Documents and Settings\mderbois-ext\Mes documents\Téléchargements\NI VeriStand FPGA Interface Tools 2010+\Files\2010\resource
D:\Documents and Settings\mderbois-ext\Mes documents\Téléchargements\NI VeriStand FPGA Interface Tools 2010+\Files\2010\Targets
D:\Documents and Settings\mderbois-ext\Mes documents\Téléchargements\NI VeriStand FPGA Interface Tools 2010+\Files\2010\user.lib
D:\Documents and Settings\mderbois-ext\Mes documents\Téléchargements\NI VeriStand FPGA Interface Tools 2010+\Files\2011
04-25-2012 10:50 AM
So you see the error 6 dialog?
Can you try a few things:
If this doesn't work, you can always manually install by copying the folders from inside here:
To here:
04-25-2012 11:05 AM
Thank you !
It is working when I run the installer from C.
04-26-2012 10:23 AM
Hi Stephen,
Is it possible to take advantage of hybrid mode of FPGA with this tool ?
I would like to use some channels with FPGA and some with the Scan Engine (with EtherCAT and Scan Engine Custom Device).
As Scan Engine is taking 2 DMA FIFO and this tool 2 as well, I guess it is not possible...
Thanks for your time and help,
Maxime
04-26-2012 10:25 AM
Good question. As you noticed, it is only possible for targets with 4 or more DMA FIFOs... which is only the 9075 and 9076 chassis (note, these do not support the 986x XNET modules).
06-02-2012 06:17 AM
Hi Stephen,
Thank you for starting the discussion.
I am trying to implement two PWM channels on FPGA whose frequency, duty and phase difference can be runtime
changed by the application running on RT. That is , the values of frequency, duty and phase difference should be passed
by the application on RT to the FPGA and accordingly PWM's should be generated.
My RT is PXI-8186 and FPGA is PXI-7831R.
I am following the tutorial on link: https://decibel.ni.com/content/docs/DOC-13815
But i am not able to do it successfully. There seems a problem in communication between RT and FPGA.
I have used "square wave generation block" which has controllable frequency, duty and phase.
I am attaching the entire project below.
Please guide.
