08-15-2011 02:36 PM
The client I was using was from link here:
http://www.prosysopc.com/opc-downloads.php
Specifically the Prosys OPC UA Java SDK implementation. There is a quick registration and takes a day or two for acess. It comes with a good client example.
I will try the Inductive Automation example again today.
08-15-2011 06:58 PM
After retesting, I was able to successfully use the inductive automation server and client to browse the NI opc ua server address. Thanks for verifying and sorry for the erroneous problem report.
08-18-2011 07:39 AM
Hi Mark,
I can use the Server and Client example on the same Windows machine, it works fine. I'm using LV-2011.
Then, I would like to run the Server on a cRIO-9025 controller and keep the client on the Windows machine.
I installed the support for Server API on the cRIO, I can successfully deploy the code on the cRIO and launch it but when "Create.vi" (server) function is called, error -356519 (LabVIEW: (Hex 0xFFFA8F59) Fail to add one or more certificate files.) is returned. I certainly missed something in terms of what I should have installed for certificates.
Vincent
NB: to confirm, I a join a screenshot of my MAX screen for cRIO.
08-18-2011 09:42 PM
You need to install both server and client, even if you just use one of them.
It's a bug.
08-19-2011 03:17 PM
08-19-2011 03:59 PM
I follow this thread silently. But we, the department of research technology at a German research institute, are interested in an open communication between different control systems. It's important that the OPC communication takes place in a real open environment in future. And that the server will not be a central Windows PC. I hope that the normal user will get a framwork from NI in order to can communicate via OPC UA in future.
Best Regards and best success,
Frank
08-21-2011 08:49 PM
I'm sorry that the client example cannot work on RT. It's for Windows only. The example uses some functionality such as pushbutton's mechanical action and front panel event which are not supported on RT. So you need to avoid these functions when you create your UA RT application.
But I think you cannot even deploy the client example to RT. Can you give a screenshot of the error? Is it a pop-up dialog box or an error out from connect.vi?
A simple client example that runs on RT is like below
connect -> disconnect
09-09-2011 01:58 PM
Ryan.S wrote:
Thank you for the feedback. Both the variant read/write and data change event on server were in our proposal list. We were not sure if user really needed it. And the data change event on server may have performance issue. So we didn't develop them in this download.
We will think about these features.
I'd like to add my support for server-side data change events. That would be valuable for our projects.
Mark Zvilius
09-13-2011 08:00 AM
I look at the latest additions on this forum, and we have tested your program and its limitations.
We also believe that the standard OPC UA will have a very important place in the future to interface various materials.
As part of an important project of telescopes array, we look at this OPCUA, to interface and control the hardware (server OPCUA).
We will be happy when the OPCUA server will be embedded in a compactRio.
Under these conditions, we could consider the NI products as a good solution to interface the hardware.
So congratulations for the initiative and good development around OPCUA.
jean luc
09-13-2011 08:25 AM
Jean Luc,
You should be happy now. OPC UA server will work in a RT Target now. I've already tested a OPC UA server in my Real-Time ETS PC. There should be no reason it would not work in a cRIO. Now if NI would only update the UA server to support events, then I would actually start using it more.
David
