NI Labs Discussions
I have a question ! Plz, many peoples help me!
This block-diagram has an error. But I can't fix the this code.
I wonder how can i fix the program.
And others.. Releasing a trigger high signals, voltage signals output.
(3,769 Views)
Hi Yulslaw,
The top DAqmx task you are creating is an Analog Output (write) task, but in the while loop you are trying to perform a read. Try changing that function to a write or the task to a read and this should work.
Hope this helps,
Nick
(3,345 Views)
Thank you
(3,345 Views)
