下位机是PXIe-8840 用MAX可以连接下位机,显示正常,用veristand连接运行时显示如下错误:
?Start Date: 2019/3/11 16:28
?Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2017\Projects\ADD\ADD.nivssdf
?Initializing TCP subsystem...
?Starting TCP Loops...
?Stopping TCP loops.
Waiting for TCP loops to shut down...
?TCP loops shut down successfully.
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307853 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: The VeriStand Gateway was unable to establish a connection with the target. Confirm that the target is running and that the VeriStand Engine successfully has started. If you still cannot connect to the target, use MAX to reinstall the NI VeriStand Run-Time Engine to the target.
NI VeriStand: Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001
<append>=========================
NI VeriStand: Error 63 occurred at Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001中的打开TCP连接
Possible reason(s):
LabVIEW: 串行端口接收缓冲区溢出。
LabVIEW: 服务器拒绝网络连接。
Target: 192.168.1.101
?Unloading System Definition file...
这个哪位大神帮忙看一下啊,谢谢!
已解决! 转到解答。
