I use PCI-6024E to perform a DAQmx task and a data acquisition through traditional DAQ.
The DAQmx task is to output a voltage through AO0 channel on PCI-6024E and the data acquisiton is through AI1 channel.
From the data sheet, the two channels are not conflict each other.
For i am a newer to DAQ, can you give more details?
thanks a lot!
