压缩对应的tdms报错(the tdms file can not be compressed)可以打开这个奇怪的文件...(when open the file...)压缩或拷贝此tdms报错(when we copy or compress the tdms file, an error occur:during reading the file))报错的的tdms文件多出一个类似的文件,但是扩展名不一样,是.tdms.log ( we found a strange file named " *.tdms.log "appear )
各位大神们好,最近遇到一个奇怪的现象,我写入电脑的tdms文件有一些文件打不开(不是所有),也不能压缩,不能拷贝(报错信息如上图所示),打开的话电脑就会卡死,而且打不开的文件都有新生成一个奇怪的对应的后缀为“.tdms.log”的文件,此文件可以打开,打开后信息如图所示,不知是我labVIEW软件的问题还是和我电脑硬件有关,各位有没有什么解决办法或工具可以打开这种文件,谢谢。
Hi, buddy, I have encountered a strange phenomenon recently. Some of the TDMS files I wrote to my computer can't be opened (not all of them), nor can they be compressed or copied (the error information is shown in the figure above). If I open them, the computer will be stuck, and the files that can't be opened will be newly generated with a strange corresponding suffix of " tdms.log ”This file can be opened After opening, the information is shown in the figure. I don't know if it's LabVIEW software problem or my computer hardware problem. Do you have any solutions or tools to open this file? Thank you.
