i also have this problem.i write a conmand to the turntable by using VISA-Write based on the
turntable controling protocol, but the rotary table did not work. can you do me a favor? or do you have a example program about rotary table ?
Check with the manufacture, see if they have an example in other programming language, such as C, C++, VB.
thank you vary much! i have worked it out. But i have another problem. When i bulid connection with Agilent E8363B PNA by LNA, the read function always appears error. what can i do?
