NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
ECU MC Tookit and Veristand
Hi ,
I deploy measurement and calibration variables to lower computer by Veristand when I plan to use the CCP function of Custom Devices to calibarate ECU.It appears errors as follows:
?Loading System Definition file: E:\exer-veristand\CCP\CCP\CCP.nivssdf
?Initializing TCP subsystem...
?Starting TCP Loops...
?Connection established with target Controller.
?Preparing to synchronize with targets...
?Querying the active System Definition file from the targets...
?Unloading System Definition file...
?Connection with target Controller has been lost.
?Preparing to deploy the System Definition to the targets...
?Compiling the System Definition file...
?Sending reset command to all targets...
?Preparing to deploy files to the targets...
?Starting download for target Controller...
?Opening FTP session to IP 169.254.159.200...
?Processing Action on Deploy VIs...
?Gathering target dependency files...
?Downloading CCP.nivssdf [46 kB] (file 1 of 2)
?Downloading CCP_Controller.nivsdat [101 kB] (file 2 of 2)
?Closing FTP session...
?Files successfully deployed to the targets.
?Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 1003 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW:  无法执行该VI。通常原因是VI断开或无法定位子VI。选择文件>>打开可打开VI并确保可以运行该VI。
NI VeriStand:  Custom Devices Storage.lvlib:Open Device Reference (HW Interface).vi->Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi->NI VeriStand Engine.lvlib:Initialize Inline Custom Devices.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi中的打开VI引用<APPEND>
c:\ni-rt\NIVeriStand\Custom Devices\XCP and CCP Master\XCP and CCP Master RT Driver VI.vi
My questions are what causes this error and how to solve it.
0 项奖励
1 条消息(共 3 条)
3,764 次查看
Hello
I met with the same error, have solved the problem or have some solutions?
0 项奖励
2 条消息(共 3 条)
2,249 次查看
1. Make sure Real-Time system has the same version software as those in your Host PC. (Re-install all softwares for real-time target in NI MAX)
2. As far as I know, NI "Automotive Diagnostic Command Set Toolkit" crashes with "ECU Measurement and Calibration Toolkit", keep "ECU Measurement and Calibration Toolkit" ONLY in your host PC.
3. Since the latest version of ECU Measurement and Calibration Toolkit is released in 2015, if your LV/Veristand is not the 2015 or earlier version, try to open "XCP and CCP Master\XCP and CCP Master RT Driver VI.vi" with your LabVIEW.
Good Luck!
Xiaohui Wang
0 项奖励
3 条消息(共 3 条)
2,233 次查看
