NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
6014板卡输出问题
任务是从6014板卡输出1000Hz正弦波电压信号
question1:程序通过调试,但实际上没有电压输出。是程序错误还是硬件问题?程序见附件
question2:Daqmx Create Virtual Channel只能用默认或RSE方式输出,否则返回错误代码。这是为何?
0 项奖励
1 条消息(共 3 条)
4,037 次查看
question1:
The question may not be there is no signal out, may be the question is you just did not acquired the signal. I'd prefer to use a standalone oscilloscope to acquire to signal, or use another VI with AI task in it, just don't put the AO and a AI DAQ assistant in a signal loop.
question 2:
As you can see from the Error Message, an analog output task can only work under RSE terminal, if you want to use a differencial output, you can only use to AO channel to group a differencial AO all by yourself
Best Regards
Hu Yu
2 条消息(共 3 条)
4,026 次查看
谢谢!继续学习中……
0 项奖励
3 条消息(共 3 条)
3,999 次查看
