我再在用MCU驱动TNT5002,使用NI提供的ESP-488软件包,我把程序移植到我的平台上后可以正常接收上位机发送的SCPI指令,收到SCPI指令后可以发送数据回复上位机,上位机可以收到TNT5002发给它的数据,但每次在回复上位机前都会产生一个超时错误(INTERFACE_ERROR = 3),而且如果我设置的超时时间是1秒,上位机发送SCPI指令后TNT5002要间隔1秒才能回复上位机,请问Set_Timeout(0xc,TRUE); 这个超时的设置有什么作用?为什么每次回复上位机数据前INTERFACE_STATUS中的ERR标志都会置位?
下面是main函数的代码:
int main(void) { char keystroke; int spoll_count=0; Mem_Init(); Gpmc_Init(); Initialize_Interface(); /* Initialize TNT */ Set_Timeout(0xc,TRUE); /* Change timeout to 1 sec. */ Set_4882_Status(SRE,0x10); /* Set SRQ on MAV */ Set_Address_Mode(0); /* Set to single primary mode */ Change_Primary_Address(12); /* Set primary address */ while(keystroke!='q') { /* Loop until 'q' pressed */ do { if(Read_GPIB_Lines()&0x8000) printf("\nATN asserted"); Update_INTERFACE_STATUS(); /* Update status word */ usleep(1000); } while(Read_GPIB_Lines()&0x8000); /* Continue when ATN not asserted Update_INTERFACE_STATUS()*/ /* calls CPT_Handler() which validates the HS488 and mult- */ /* primary addresses. These bytes must be read from the GPIB*/ /* before an I/O function can be called. */ //当ATN未断言时继续Update_INTERFACE_STATUS()调用CPT_Handler(),该CPT_Handler()验证HS488和多主地址。 //必须先从GPIB读取这些字节,然后才能调用I/O功能。 if(INTERFACE_STATUS&SPOLL) { /* If SPOLL set */ Set_4882_Status(STB,spoll_count++); /* Set count of SPOLL */ Clear_4882_Status(STB,0xff); /* Clear STB */ } else if(INTERFACE_STATUS&LACS) { /* If listen addressed */ Receive(buf,50,EOI); /* Read up to 50 bytes */ /************************************* * * Parse commands/data * *************************************/ if( strcmp(buf , "*IDN?\n") == 0 ) { flag = 1; } else if( strcmp(buf , "1234\n") == 0 ) { flag = 2; } else if( strcmp(buf , "56\n") == 0 ) { flag = 3; } else if( strcmp(buf , "78900\n") == 0 ) { flag = 4; } else { flag = 0; } if(DATA_COUNT>0) { /* If bytes were received */ Set_4882_Status(STB,0x10); /* Set MAV bit in STB */ /* Print to stdio */ printf("\nReceived %lu data bytes\n",DATA_COUNT); printf("\nReceive %x = %s\n",buf, buf); } } else if(INTERFACE_STATUS&TACS) { /* If talk addressed */ /* Send status data */ if( flag ==0 ) { DATA_COUNT = 0; flag = 0; } if( flag == 1 ) { flag = 0; Send("flag = 1",8,EOI); } if( flag == 2 ) { flag = 0; Send("flag = 2",8,EOI); } if( flag == 3 ) { flag = 0; Send("flag = 3",8,EOI); } if( flag == 4 ) { flag = 0; Send("flag = 4",8,EOI); } if(DATA_COUNT>0) { Clear_4882_Status(STB,0x10); /* Clear MAV bit */ /* If data bytes sent print it */ printf("\nSent %lu data bytes",DATA_COUNT); } } if(INTERFACE_STATUS&ERR) { /* If EABO report it */ //INTERFACE_ERROR = ENOL(1):没有听者 //INTERFACE_ERROR = EARG(2):函数参数错误或不能进行某种参数设置 //INTERFACE_ERROR = EABO(3):超时 printf("\nGPIB error has occured (INTERFACE_ERROR = %d)",INTERFACE_ERROR); INTERFACE_STATUS&=~ERR; } } Interface_Off(); /* Disable interface */ Gpmc_free(); Mem_free(); return 0; }
