NI LabVIEW,CVI,数据采集等产品讨论区
移除前面板的vi无法编译(Error when build exe without block diagram)
Highlighted
当我把程序中部分vi通过source distribution 发布之后,将发布的vi替换掉原来的vi,编译时出现以下错误,请问是什么原因?
Unable to remove unused polymorphic VI instances for this application. Choose a different option on the Additional Exclusions page and build the application again.
Error 1073 occurred at AB_Engine_Disconnect_Typedefs.vi -> AB_Source_VI.lvclass:Copy_SourceItem.vi
Possible reason(s):
LabVIEW: This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
(485 Views)
Highlighted
Accepted by topic author Zer0rez
编译时别选这些选项.
George Zou
(455 Views)
Highlighted
谢谢!
(446 Views)
