NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
移除前面板的vi无法编译(Error when build exe without block diagram)
已解决!
转到解答
当我把程序中部分vi通过source distribution 发布之后,将发布的vi替换掉原来的vi,编译时出现以下错误,请问是什么原因?
Unable to remove unused polymorphic VI instances for this application. Choose a different option on the Additional Exclusions page and build the application again.
Error 1073 occurred at AB_Engine_Disconnect_Typedefs.vi -> AB_Source_VI.lvclass:Copy_SourceItem.vi
Possible reason(s):
LabVIEW: This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
0 项奖励
1 条消息(共 3 条)
2,142 次查看
解答
接受人 Zer0rez
编译时别选这些选项.
George Zou
2 条消息(共 3 条)
2,112 次查看
谢谢!
0 项奖励
3 条消息(共 3 条)
2,103 次查看
