您好,
请问您在使用什么版本的LabVIEW 呢?
http://digital.ni.com/public.nsf/allkb/550D9CEF0EE39F2F86257BE800728A7B?OpenDocument
您是用LabVIEW还是 LabWindows? 它显示的错误在SharedLib.c
您电脑的操作系统是什么位数和版本?
您好,
在上一次的链接中关于Error -2147221480
This is a known issue with LabVIEW 2013, and it is tracked by CAR 400810. This behavior only occurs if you are on a Windows account without administrator privileges and with User Account Controls turned on.
To fix the issue, delete all the files located at %APPDATA%\..\Local\VirtualStore\Program Files\National Instruments\Shared\LVDB
另外,LabVIEW 2013 和 Win 10,64-bit 是不兼容的,需要2015 SP1 以上的版本 http://www.ni.com/product-documentation/52818/en/
