At first,thanks for your answer!
If I understand your last sentence collectly,I really want to package my prograss.I need to make my front panel more acceptible to others,and I think that the two functions is necessary.Now,my problem is missing.Perhaps you will be surprised about it,I share the same feeling with you! I wish that I would not confront of this problem for ever.
I look forward to the next exchange~
您好!我现在也是遇到这个问题了,选择窗口为“”默认“状态运行就可以同时使用,但是选择为“模态”运行时,就不能同时使用,如果不勾选“允许调整窗口大小”,就可以最小化,如果勾选了“允许调整窗口大小”,就不能最小化了,确认没有用程序代码控制!请问有没有什么解决办法,我的窗口必须使用“模态运行”,但是我又希望两种功能都能使用,谢谢!
