可能有这个限制 If you try to send more than 4096 bytes with UDP_Write VI under Lv RT 7.1, you will receive "error 266" which means that the network connection has been closed by the peer. This problem does not appear under Windows. And, there is no information about such functionnal limit in the documentation.The problem is still Fixed Pending.
