运行时提示不存在子VI NI_vision_acquisition_software.lvlib:IMAQdx Open camera.vi
但是我都将NI_vision_acquisition_software.lvlib与IMAQdx Open camera.vi拷贝到应用程序运行目录下了。
提示截图如附件
谢谢,生成可执行程序规范时如何添加vision module. 另外在依赖关系中NI_vision_acquisition_software.lvlib被加锁了,没有 密码。
在本机上好象是激活了,可以执行生成的可r执行程序,但在其它电脑上才出错。还提示 :
When you create installer, add Vision module.
You can't add Vision module when create exe.
Use what or where i can find the installer? Does this related with the run time engine or real-time module?
In the project, the same place you create exe script, after you create exe, create an installer, so you can install on other computer.
You can include runtime engine and / or real time module in the installer.
Thanks. It succeeds after using the installer. However the installer package is more than 1GB for several needed modules. while it works, it is OK.
