NI LabVIEW,CVI,数据采集等产品讨论区
不存在子VI NI_vision_acquisition_software.lvlib:IMAQdx Open camera.vi
Highlighted
运行时提示不存在子VI NI_vision_acquisition_software.lvlib:IMAQdx Open camera.vi
但是我都将NI_vision_acquisition_software.lvlib与IMAQdx Open camera.vi拷贝到应用程序运行目录下了。
提示截图如附件
Message 1 of 8
(8,244 Views)
Highlighted
1. Vision module 激活了吗?
2. Login as admin ?
George Zou
Message 2 of 8
(8,231 Views)
Highlighted
谢谢,生成可执行程序规范时如何添加vision module.  另外在依赖关系中NI_vision_acquisition_software.lvlib被加锁了,没有 密码。
在本机上好象是激活了,可以执行生成的可r执行程序,但在其它电脑上才出错。还提示 :
无法找到组件 NIPALP.DLL,因此这个应用程序未能启动。重新安装应用程序可能会修复此问题。
无法找到组件nirpc.dll,因此这个应用程序未能启动。重新安装应用程序可能会修复此问题。
无法找到组件ni_emb.dll,因此这个应用程序未能启动。重新安装应用程序可能会修复此问题。
Message 3 of 8
(8,226 Views)
Highlighted
When you create installer, add Vision module.
You can't add Vision module when create exe.
George Zou
Message 4 of 8
(8,226 Views)
Use what or where i can find the installer? Does this related with the run time engine or real-time module?
Message 5 of 8
(8,223 Views)
Highlighted
In the project, the same place you create exe script, after you create exe, create an installer, so you can install on other computer.
You can include runtime engine and / or real time module in the installer.
George Zou
Message 6 of 8
(8,220 Views)
Highlighted
Thanks. It succeeds after using the  installer. However the installer package is more than 1GB for several needed modules. while it works, it is OK.
Message 7 of 8
(8,209 Views)
Highlighted
You can download Vision installer from NI.
Install it separately.
George Zou
Message 8 of 8
(8,174 Views)
