NI FlexRIO Network
Problems with Component Level IP
Hello, so i created an VHD , XML and FAM files for my flexrio module. I followed all steps as it says in FlexRIO Adapter Datasheet.
When i am creating new project with FlexRio module in it, than right clicking on IO Modules and go to Properties, it should've showed my .fam file in it. It shows my .fam life without errors, but when i am clicking on title to find .XML  CLIP file in it , it says  "No IO Module CLIPs found" . I checked all my files , everything is totally fine, can someone help me with this issue , thanks
(3,716 Views)
What directory have you placed your CLIP files in?
It sounds like you have placed your .FAM file in the correct location but that the correspoonding xml file that describes the CLIP signals can't be located correctly.
Can you confirm that the xml file for your CLIP is in the same directory or a sub directory of the location that the .fam file is located?
(3,519 Views)
