06-08-2012 06:04 PM
I'm attempting to simulate some I2C code which will write data into the adapter module EEPROM. I have found that I can build the I2C code into a bitfile, however I can't get the simulation build to complete. I get the following error (-61499):
I noticed that if I disable some of the blocks:
and then remove the i2crddata line and replace it with a constant (so: 'i2crddata' I/O pin would be replaced with a constant number '0' (in FXP) for example)
It will build successfully and I have no clue why....
I've zipped and attached the LV project for reference which includes the full code and CLIP.
Anybody know why this is happening?
06-11-2012 09:34 AM
Hello!
For this issue, I would suggest creating a service request at ni.com/support with one of our Applications Engineers. They will be able to help debug/troubleshoot this situation as well as be able to access the applicable internal resources to investigate this issue.
