NI FlexRIO Network
DRAM model behavior
I am trying to simulate socketed DRAM CLIP before I get FlexRIO hardware...
I make simple test, but i get little bit strange results...
Labview model and my VHDL code of my component is below...
dram_data_mask_lower <= (others => '0');
dram_data_mask_upper <= (others => '0');
process(aReset, clk) begin
    if(aReset = '1') then
        dram_write_data_lower <= (others => '0');
        dram_write_data_upper <= (others => '0');
        data_value_count <= (others => '0');
        dram_address <= (others => '0');
        dram_command_write_enable <= '0';
        dram_command <= (others => '0');
    elsif rising_edge(clk) then
        if(dram_command_init_done = '1' and dram_command_fifo_full = '0') then
            data_value_count <= data_value_count + 1;
            dram_write_data_lower(31 downto 0) <= data_value_count;
            dram_write_data_lower(63 downto 32) <= data_value_count;
            dram_write_data_upper(31 downto 0) <= data_value_count;
            dram_write_data_upper(63 downto 32) <= data_value_count;
            dram_address(31 downto 2) <= data_value_count(29 downto 0);
            dram_command_write_enable <= '1';
            dram_command <= "00000000";
        else
        end if;
    end if;
end process;
DRAM memory simulation model have limit at 2^18 addresses(1MegaByte)...
I wrote sequentially from the address zero until the end of this valid range...
On every 100MHz clock...
But the model always accept the data...
How this is possible?
I fill 256 rows with 1024 columns with data, before simulation finish...
Where is the overhead for the refresh and for precharge row and open the row...
I expect to see sometimes that controller is busy...
How accurate is this short DRAM model of the physical DRAM components?
(6,064 Views)
Unfortunately, in my experience - the simulation model of the DRAM appears to act like an SRAM (ie: no refresh/charge effects) with a 15-ish clock latency.  It does NOT operate that way in hardware, so you should have a buffering scheme on the data inputs and outputs to minimize data-loss.
-J
(4,743 Views)
I have a different suggestion, although it isn't really pertinent to your simulation question.
Since you appear to be developing a new application, you should strongly consider using the DRAM Memory Primitive instead of the DRAM CLIP.  The simulation of this is still not 100% accurate to hardware latency/etc.  However, there are very few use cases where you still must use the DRAM CLIP.  The interface on the DRAM Primitive is much cleaner, and much easier to manage buffering schemes.
(4,743 Views)
Since I am planning to use DRAM memory on the edge of maximum throughput performance...
I managed to make an accurate verilog model using available NI and Xilinx files...
Who is interested can see  in attached files...
Thanks to all
(4,742 Views)
