07-24-2019 09:55 PM
While running NI ELVISmx Oscilloscope for ELVIS II at CH0 or CH1 I'm getting error -200077.
The error states:
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in ELVISmx_subScopeAcquire2.vi->ELVISmx_subScopeAcquireData.vi->Scope.vi
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Device: Elvis
Property: SampQuant.SampPerChan
Value: 1
Maximum Value: 16384
Minimum Value: 2
Task Name: _unnamedTask<1>
Any suggestion?
07-24-2019 10:00 PM
07-24-2019 10:32 PM
Many thanks sir, but is there a way to change the value at ELVISmx? or at MAX? I am a newbie
07-25-2019 12:24 AM
The property would correspond to "Record Length". You can change the value on Configuration Tab.
http://zone.ni.com/reference/en-XX/help/372500F-01/372500f/elvisexpress_oscilloscope/
08-21-2019 05:21 AM
Hi Erwin,
This is a known bug for the 2019 version of the ELVISmx software and has been targeted for a fix in the next patch.
For the time being, I recommend upgrading to the 2018 version of the software.
Cheers!
Jacob
01-27-2020 12:20 PM
I get the same error using the elvismx 2018 version. It's possible to use the AI but not the channels.
07-08-2022 12:59 AM
07-08-2022 01:01 AM
请问如何解决的?我卸载Elvismx重装后,还是这样,怎么办?
