NI ELVIS
Reply
[ELVIS III] how can use oscilloscope vis
how can use oscilloscope vis??
I want to see the waveform like measurement live
but i don't know what should i do
please help
(470 Views)
Highlighted
Re: [ELVIS III] how can use oscilloscope vis
You'll need to place the Scope Initialize, Auto Setup, and Start VIs outside of the loop as shown in the picture below. The VIs on the top row configure the FGEN to produce a square wave on channel fgen/1. You can change the DC offset to shift the voltage values higher if necessary.
(379 Views)
I am trying to generate the signals through labview and access these signals using DAQ. I have attached the code and obtained results below. Why the signals are looking like that in oscilloscope. how to correct it?
(126 Views)
