NI製品ディスカッション
キャンセル
次の結果を表示
次の代わりに検索
もしかして:
ni5660 intialize.VI
Hello Everybody,
I use the Ni 5660 spectrum analyzer with labview 8.2, the Niscope and NiRFSA toolkits.
Needing to make some program, I started by having a look in the given example.
Unfortunately, none of the given example worked properly. Some of the sub-VI they use are missing.
For example, the ni5660_etting_started.vi uses the sub VI called ni5660-initialize.vi. This sub-VI uses sub-sub-VI which cannot be found, such as MT_initialize_receiver_info.vi or MT_set_attribute.vi.
It appears that this sub-sub-VI can be found in the modulation toolki that I does not own.
My questions are:
- Did I missed something in the instalation of the RFSA toolkit?
- Does the RFSA toolkit to work propoerly requiers the Modulation toolkit?
Thank you for your help
0 件の賞賛
メッセージ1/2
2,938件の閲覧回数
Hello
My name is Nishantha Fernando from National Instruments Japan. Thank you for your inquiry.
I am really sorry for the late update. Did you able to solve this issue?
I came to know that you already got an answer for this in the following link here.
Please let me know if you still have any problem regarding this
Thank you very much.
Regards
Nishantha Fernando | Applications Engineer | National Instruments Japan Corporation
0 件の賞賛
メッセージ2/2
2,796件の閲覧回数
