Hi, I'm Nori.
I found an error when running RT.
I'm developing RT program using Ethercat NI 9144 on PXI 8108 on LabVIEW8.6
I think all required sacn engine, drivers are installed enough.
It was no issue to connect to the PXI but when I tries to deploy the ethercat master,
error dialog attached below comes out and can't open the VI.
Two c-RIO moduls ,NI9205 AI+-10 and NI 9213 TC are set into the ethercat chassis.
Could you tell me what driver is required to deploy the ethercat?
I attached the report what software is installed currently on the target.
I'm sorry for the inconvenience, the report is written in Japanese but you could see " software".
Then you
could see what software is installed .
Sincerely,
Nori
softeware configuration
- NI-PXI8108-2F126F96
- AMD AM79C972 10/100Mbps Ethernet Driver 1.0.0.3.0
- Broadcom 57xx Gigabit Ethernet Driver 3.0.0.3.0
- IndCom for EtherCAT Scan Engine Support 2.0
- Intel 1000e Ethernet Driver 1.0.0.2.7
- Intel 8254x Ethernet Driver 3.1.0.3.1
- Intel 8255x 10/100Mbps Ethernet Driver 3.0.0.3.0
- LabVIEW Real-Time 8.6.1
- NI RT Extensions for SMP (MultiCore Support) 10.0
- Web Server for LabVIEW RT 1.0.1
- Language Support for LabVIEW RT 1.0.0.3
- Microsoft Visual Studio 2008 Runtime Support 1.0
- NI Scan Engine Advanced I/O Access 1.0
- NI-1394 External Drive Support 1.4.2.3.0
- NI-DAQmx 9.1.5
- Multifunction DAQ (E, M, S, X, and SC Express Series)
- AO SERIES
- TIO SERIES (Counter Timer)
- DIGITAL I/O
- NI-653x
- Dynamic Signal Acquisition
- NI-SCXI
- Switches
- NI-FGEN 2.6.0
- NI-RIO 3.5.0
- NI-SCOPE 3.6.2
- NI-Serial RT 3.6.0
- NI-SWITCH 4.0.2
- NI-Sync 3.2.1
- NI-VISA 5.0
- NI-VISA GPIB Passport
- NI-VISA ENET-ASRL Passport
- NI-VISA ENET Passport
- NI-VISA PXI Passport
- NI-VISA Remote Passport
- NI-VISA Server 5.0
- NVIDIA Ethernet Driver 3.0.0.3.2
- System State Publisher 2.0.0
