05-02-2018 02:13 AM
05-02-2018 02:32 AM - 編集済み 05-02-2018 02:33 AM
Hi aneu,
your AO values need to stay within your min/max values defined when setting up the AO channels!
When the AO channel can only handle values in the range of ±10V then you cannot output 24V…
General hints:
- When posting in an English speaking forum you shoul dwrite in English…
- Using non-ASCII chars in filenames always gives problems with "standard English" Windows installations and also with "standard English" LabVIEW versions…
