I am using an x-y chart and I allow the user to select auto. scale
and default scale as appropriate using the property node.
Sometimes, when the scale is changed, one of the scale
is overlap, one of the scale is constant. This problem is not
always repeatable but occurs at window vista regularly and I
have recently discovered it in a LV built exe also (when the exe
is restarted it's OK). I am using LV8.5.
Has anyone got a fix for this?
