Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
在 11-16-2017 10:53 AM
Hi NI & ALL
env. CVI 2010,
I packet my files and installed it, but I can not run uninst.exe.
How to fix this problem?
Help me, please....
在 11-16-2017 12:18 PM
What happens if you follow the instructions on the popup dialog?
在 11-18-2017 09:34 PM
In Windows Control Panel, Remove Program is well.
But I want to use uninst.exe to remove this application.(Not just a pop-up message) What should I do?
Thanks for the prompt reply.
在 11-19-2017 02:04 PM
What if you run it as admin? (right-click...run as administrator)
Thanks!
We'll be in touch soon!
