os:windows xp sp3
Microsoft Visual Studio 2008 vb.net
Measurement Studio 8.6
會出現下列錯誤,我又沒辦法擷取錯誤,請問有什麼方法可以解決嗎。
System.InvalidOperationException 未處理
Message="集合已修改; 列舉作業可能尚未執行。"
Source="mscorlib"
StackTrace:
於 System.Collections.Hashtable.HashtableEnumerator.MoveNext()
於 NationalInstruments.UI.Internal.InnerAxisElement.a(ComponentDrawArgsInternal A_0, RectangleF[] A_1)
於 NationalInstruments.UI.Internal.InnerAxisElement.DrawForeground(ComponentDrawArgsInternal args)
於 NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1, Boolean A_2)
於 NationalInstruments.Restricted.ControlElement.DrawChildren(ComponentDrawArgsInternal args, Rectangle clipRectangle)
於 NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1)
於 NationalInstruments.Restricted.ControlElement.Paint(PaintEventArgs e)
於 NationalInstruments.UI.WindowsForms.ControlBase.OnPaint(PaintEventArgs e)
於 System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
於 System.Windows.Forms.Control.WmPaint(Message& m)
於 System.Windows.Forms.Control.WndProc(Message& m)
於 System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
於 System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
於 System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
於 System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
於 System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
於 System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
於 System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
於 System.Windows.Forms.Application.Run(ApplicationContext context)
於 Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
於 Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
於 Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
於 WindowsApplication11.My.MyApplication.Main(String[] Args) 於 17d14f5c-a337-4978-8281-53493378c1071.vb: 行 81
於 System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
於 System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
於 Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
於 System.Threading.ThreadHelper.ThreadStart_Context(Object state)
於 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
於 System.Threading.ThreadHelper.ThreadStart()
InnerException:
在 04-22-2010 11:09 PM
如果不是以下二者請升級,請告知升級後是否出現此現象
visual studio 2008 sp1
measurement studio 8.6.1
http://digital.ni.com/public.nsf/allkb/961CB182B0F3C2EE8625755F0066A47D
我已試到答案但不知是否正確,目前run都沒問題
ScatterGraph1.Plots.Item(0).XAxis.Mode = AxisMode.AutoScaleLoose
ScatterGraph1.Plots.Item(0).YAxis.Mode = AxisMode.AutoScaleVisibleExact
將mode改變一下就行了
在 04-26-2010 12:06 AM
請問軟體版本是???
vs 2008 sp1???
mstudio 861???
Visual Studio 2008 sp1
請問8.6.1是指Measurement Studio 2009 嗎
在 04-26-2010 12:55 AM
plz download http://joule.ni.com/nidu/cds/view/p/id/1282/lang/zht
or attach your code here.
We have 8.6.1 here and can test for you.
