Contents
The following drivers are included in the August 2015 System Driver Set:
Instrument Control
NI-488.2 15.0
NI-VISA 15.0
NI-Serial 15.0
IVI Compliance Package 15.0
PXI Platform Services 15.0.1
NI-PXImc 14.0
NI-VXI 3.9.0
To download the August 2015 driver set run the downloader attached to this document. Note that this download is larger than 4 GB. Please follow the instructions in KnowledgeBase 5JHC2SDX for downloading this file.
KnowledgeBase 5JHC2SDX: How Can I Download National Instruments Software Larger than 4 Gigabytes?
在 05-06-2019 09:18 PM
您好,
请问您使用的硬件和电脑的操作系统是什么?
官网上有比较新的版本:http://www.ni.com/zh-cn/support/downloads/drivers/download.ni-488-2.html
windows7,用labview2013编程,生成安装程序提示找不到NI-488.2
谢谢,这个太大了,有单独的NI-488.2吗
05-13-2019 03:23 AM - 已編輯 05-13-2019 03:31 AM
单独的 NI-488.2 可參考 carmen9
@carmen9 已寫:
您好,
LabVIEW與NI-488.2版本相容性- National Instruments
在 05-15-2019 09:42 PM
您好 雾里花,
如果是LabVIEW 2013以上可以使用 16.0的版本,但是需要Win 7 SP1 。
17.6 之前的版本已经在官网上不提供了:https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QOfSAM
16.0 的下载链接请看您的Inbox。
