Dear All,
I get error message (timeout), What’s wrong with this VI?
Step 1 Used the NI MAX or Keysight’s IO library find the Instrument from the TCP/IP Socket Port 5025 and read information by SCPI *IDN?\n
(Configuration: TCP/IP Socket Port 5025 Enable Termination/Line Feed (10=A))
Step 2 Close NI MAX or Keysight’s IO libraries
Step 3 Open the LabVIEW used SCPI *IDN?\n could not get the Instrument information and Socket Attributes
(Select: TCP/IP Socket Port 5025 Enable Termination/Line Feed (10=A) and run the Untitled.vi to get error message)
NI MAX [Configuration/Attribute Name] but LabVIEW [SCPI *IDN?\n vi] get error messages.
LabVIEW SCPI *IDN?\n vi
在 12-12-2019 08:53 AM
you can right click to show the radix to check the input. it is 0x10 not 0x0A.
