Muon Detector NMT Senior Design Team 2012-2013
Reply
Highlighted
Multiple class instances using Parallel For loop
I could have sworn that, in past research, I found an example of using the parallel for loop option with a class to avoid having to copy and paste every time a new instance was needed (instead for loop would adjust # of instances needed)
Is this even possible and if so, does anyone have any examples?
A few notes:
- In my situation, data is independent from each other in each class so parallel execution is desired option
- I already have multiple copy pasted instances of class so reentrancy is not the issue (many msg boards seem to have this as the answer)
- Main objective is to experiment with processor efficiency (which is a whole discussion in of itself)
- Unable to post code
Thanks for any help on a mechanism to achieve multiple instances of class (or multiple objects)
Message 1 of 1
(293 Views)
Reply
