11-19-2015 12:34 PM
Here is the whole circuit, where the 74123 is used in context. I'm using an array of comparators to send digital signals to the 74123's. These 74123's will then give a sustained pulse to indicate when the threshold has been reached.
11-19-2015 12:59 PM
I just tried the other components you suggested, at least the ones available in Multisim, the 74121 and 74130, and they gave the same error as before.
11-19-2015 05:17 PM - edited 11-19-2015 05:20 PM
hello, thanks for response.
interestigly enough, when I opened your file and started simulation - it worked just fine.take a look at the picture -
I am confused now -
nevertheless I have a few questions about curcuit itself - but it is a diffrent topic andd we could discussed it if you want to.
with hope it helps
thanks
Michael
11-20-2015 08:13 AM
Oh right, I see. It works when only one of the 74123's is grounded, as is the case in the attachment. When you attach all the rest to ground, though, it won't work.
11-20-2015 08:40 AM
Look- I've done following - I created circuit with 3 cases ( 6 pcs ) of 74123 - and tried to simulate it - it worked fine - the file in attach.
try it.
if it works for you - add more components to build your project.
with hope it helps
thanks
Michael
11-20-2015 09:48 AM
Aha! I found that by leaving the CT pin (6 and 14) open on the 74123, instead of connecting it to GND, I was able to get it to work. I need that pin to be at GND, but even when I leave it open it has a value of 0, so I don't need to connect it to GND. This is not what I will do in the actual PCB, but it seems to be an effective workaround for the multisim environment. Thank you, Michael, for your help and time, you've been very helpful!
11-20-2015 12:42 PM
sure, we have to help each other.
BTW - check your schematic - you have 6V battery connected to +5V global connection.
and another something
- it looks to me the value's of resistors in top left corner are wrong - assuming you build kind of A2D.
- using that approach with 74123 should work but, you are going to get bunch of asynchronous pulses plus need of 6 caps and 6 resistors and 3 IC's for that.
I believe there are much more elegant ways to do that - just IMHO.
with hope it helps
thanks
Michael
11-20-2015 12:47 PM
Thanks, Michael.
It is a charged particle detector. The circuit will receive a pulse signal from a preamplifier, the comparators turn on if it is above their threshold, and the 74123's emit a longer pulse that can be counted.
