Multisim and Ultiboard
vhdl component
Hi
i want to create a vhdl based component and simulate it on a circuit with some analog devices for example (to test co simulation in multisim). i tried to read this tutorial for creating a simple 1 bit adc component => http://zone.ni.com/devzone/cda/tut/p/id/5653
and followed steps to simulate the created component but it does not work at all..when ading some analog component like power source to the circuit, i get errors like :
------ Checking SPICE netlist for Design1 - vendredi 9 mars 2012, 17:16:53 ------
Error message from simulation: ERROR - node $1 cannot be both analog and digital
Error message from simulation: EVTinit: Unknown error code
======= SPICE Netlist check completed, 0 error(s), 0 warning(s) =======
i use multivhdl for creating the .vx file needed in component tool wizard
and multisim 12.0
note: in component tool wizard when multisim ask for the .vx file i try to browse and load the .vx file but i get a window saying "Spice model must be a text file", so i typed ".model cpld d_vhdl(vhdl_file="C:\......vx") in model data field and i did not use the button for importing the .vx file to bypass this error message
any tutorial for creating a vhdl based component and simulate it in multisim 12 will be great
(5,146 Views)
(5,123 Views)
Using the component wizard in Multisim you can create a VHDL component in 9 steps. Select the "Simulation and PLD export" for this example name the component Full adder, the function is a high speed 4-bit fuller Adder IC with carry out feature.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
To view model files and detailed reports, right click an existing component.
View component modelView component model
If this post helped you in any way please leave Kudos 🌟
(2,109 Views)
