‎12-27-2012 12:21 AM
I am new to using Multisim with LabVIEW using cosimulation. I want to ask if there is a PWM component in Multisim that can have its duty cycle be controlled using LabVIEW? I have an algorithm in LabVIEW that outputs duty cycle values from 0 to 1, representing duty cycle percentages.
How do I control the PWM duty cycle in Multisim using LabVIEW cosimulation?
Many thanks,
SPECTRE
‎12-27-2012 02:35 PM
Hi Spectre,
In Multisim, search for the parts base on functionality, there are some PWM models in the database. Have a look at this knowledge base if you don't know how to search for parts:
http://digital.ni.com/public.nsf/allkb/7309A5CABC677296862577ED006EC99E
Aslo, have a look at this knowledgebase:
http://digital.ni.com/public.nsf/allkb/EF391C48CF71AE4F862571B900644F84
This article shows how you can get Mutlisim and LabVIEW to co-simiualte:
http://www.ni.com/white-paper/13663/en
I hope this helps
‎10-17-2018 01:00 PM
Can You make me understand this? please
@SPECTRE
‎10-18-2018 11:08 AM
Here is a screen shot of the basic PWM function. In order to control the PWM duty cycle you input a voltage from 0 to 1.0 proportional to the desired duty cycle.
The PWM frequency and output voltage amplitude and rise/fall time are all settings of the PWM function.
‎10-18-2018 03:53 PM
Thank Dear,
