11-15-2018 01:59 AM
Hallo,
i'm trying to simulate / show the typical condensator charging. ( Multisim Component Evaluator 14 )
Power Source - Resistor - Condensator
As soon as i'm starting the simulation the voltage of Power Source and condensator is the same.
Doesn't matter which value i'm choosing for the resistor.
Which simulation setting i should change ?
Best regards
Stefan
11-26-2018 04:50 AM
Most likely, the simulation uses a fully charged capacitor (as in, your configuration has been sitting in its current state there as is) as its default value.
Try adding a switch that you can flip (default position is that there is no connection) so that the process of charging can be initiated at will.
Alternatively, use a signal source and create a square voltage that only starts being high (5V for example) after one second or so.
11-28-2018 05:06 AM
Thank you very much for your answer.
The signal source hint was the solution for my problem
