09-20-2015 07:36 PM
Hi, I am having a problem, not sure what I am doing wrong. I created a schematic symbol in multisim. Afterwards I realize I need to make a correction to some of the pin names, for example: Change from (P1_6) to GPIO(P1_6).
I get into the component editor, (see attached image) and click on the name, but I am unable to edit the name. Any suggestions? It is part 2 of a 100 pin part so I do not want to start over. Thanks
Solved! Go to Solution.
09-21-2015 03:34 PM
You can edit the pin names in the footprint editor. In the bottom you'll find a table with all the pins and their configurations. You just have to select the pin you want to change the name of and then double click it's name field. He you can also select whether the pin name will be visible or not (Symbol Pins can be set to Hidden or Visible).
09-21-2015 08:42 PM
Hi, thanks for replying. I actually tried going into the footprint editor but I still could not edit the pin name (see images).
In this field the name was uneditable, but this did lead me to try something else. Instead of edit footprint, I tried Edit component in DB.
From the symbol Tab, I was able to edit the names (see images).
So, problem solved. Thanks
09-22-2015 09:03 AM
I am glad you were able to find the solution.
Since the picture from your original post was from the Footprint Editor I included the instructions to edit the pins names from there, but the method you used is actually equivalent to that. To open the Footprint Editor you have to reach the window in which you did the edits and then click on Edit.
