Multisim and Ultiboard
potentiometer
Has any one noticed that the slide bar  is in revers, when it shows 100% it is realy showing 0 (Ohms)
Message 1 of 8
(10,180 Views)
Hello toysforlee
Actually I recreated the issue that you have and I realized that is the connection that you are using. I attached one picture with your connection and the connection that I made that has the correct value, so I would like to you try in that way just to be completely sure.
Regards
Message 2 of 8
(10,154 Views)
Hello, thanks for response
I personally do not understand what is the big deal here.
if you move wiper  from left to right or vs vs all way and the resistance is changing   from 0 to 100 % - it is fine with me.
I wish I had that kind of problems.
with hope it helps
good luck
Michael
Message 3 of 8
(10,131 Views)
Hello
Actually the issue is related with the potentiometer value (Ohms). For that reason I showed the picture before. I hope you could resolve the issue.
Regards
Message 4 of 8
(10,107 Views)
I still do not understand what is the problem/
pots value is 1kOhm
meters show 1kOhm
what is wrong?
with hope it helps
thanks a lot
Michael
Message 5 of 8
(10,090 Views)
Hello aa232004
I apologize I made a video just to explain the issue way you connect in different way the potentiometer. You are going to see the percentage won’t correspond with the value (Ohms) please see the video below:
http://screencast.com/t/wmtdCFkn
Regards
Message 6 of 8
(10,075 Views)
Please spend a little time studying how a pot works. If the pot is turned 100%, from the wiper to one end, it will read 0. From the wiper to the other end, it will read the full resistance. This is exactly what you are seeing. There is no issue at all.
Message 7 of 8
(10,060 Views)
Hello every body , thanks for response
thanks Dennis.
I would like to add - it looks like post author is confusing potentiometer    with the rheostat   and    does not  know the difference .
I agree completely - some studying should be done.
with hope it helps
good luck
thanks a lot
Michael
Message 8 of 8
(10,049 Views)
