11-08-2006 07:48 AM
11-08-2006 09:41 AM
11-08-2006 10:17 AM
I can place the pad over the hole exactly but it's the thermal relief that comes out shifted. The 3D view is not real important to me but it is nice to show others how the design is progressing. I always use all the grids at .001". I'll include a zip file of the part of the board in question. Look at the USB connector on the right , the oval mounting holes thermal reliefs are shifted.
P.S. I like your new fourms, I get responses back is a lot quicker now. Thanks
11-08-2006 12:47 PM
Richard,
I checked your design file, it indeed looks weird how the thermal relief is located way far from the pad. Anyways, the problem is in the footprint for your USB port. I have no idea how the pad was created, but I change the pad to another form (for every single layer) and after I saved the footprint to my database and replace the current one I got the thermal relief to show correctly over the custom pad.
I attached to this message your same design file, I modified the USB port custom pad to another one so please open it and let me know if you can see the new one working fine. However, please note that I moved the footprint from its original position so don't use this file for your work since I might have messed something on it, I used it for fixing the USB portion only but I did not took any precautions with the rest of your layout.
I suggest you check the footprint on your database, I guess something got messed up in there. Make sure that when you create the custom pad, you apply the same shape for all layers, and that you don't specify a lock position or something like that.
Please let me know if you got it to work after these suggestions.
11-09-2006 12:20 PM
nestor, thanks for the help. The layout position was just for you to look at . I copied your part to my database and I thought that I would be all set, but when I go and place it on my design, the DRC tells me that J6 (my part id) and J (??) are too close together or on top of each other. I have no part J and if I delete the USB PORT J6, part J disappears. I looked at the part in the database and I can't find out where that part J is coming from. When I place the part a J6 and a J appears on the silkscreen. Can there be 2 components in 1 part? Part J does not even appear in my Parts tab and this problem is keeping my netlist from finding the pins on J6.
I hope that wasn't too confusing.
Rich
11-09-2006 01:54 PM
11-10-2006 12:27 PM
nestor, I made a new part from scratch and everything is great now. The problem seems to be from my custom pad, whenever I use it the thermal relief is about .5" away, not sure why but I got it done.
Thanks again for all your help
Richard
11-13-2006 11:01 AM
Richard,
I'm glad that worked out, sometimes when a drawing has some hidden misplacements is better to re-draw it, the reason is that when the picture (footprint) is integrated as a unique entity, it makes it very difficult to go an change something that is already merged.
Thanks for letting us know that now is working...
