Multisim and Ultiboard
no 4060 ic on MS7
hey all,
i am currently using Multisim 7 (full) as this this is what i am provided with at my college
and have hit a bit of a wall with my circuit as there are no 4060 chips on this version.
is there anyway i can build one, or download an add on from somewhere?
any suggestions?
many thanx
(4,195 Views)
I am going to try and help but I am not sure the model I am going to post will actually work. The only thing I can suggest is to try it and see if  it does work for you. I hope this helps as this is all I have. Good luck.
.MODEL 4060B_15 d_chip ( behaviour= "
+;4060  14-STAGE BINARY COUNTER+OSC @15V
+/inputs  MR  RS IRTC ICTC
+/outputs ORTC OCTC O3 O4 O5 O6 O7 O8 O9 O11 O12 O13
+/wires CP
+/module NAND_4060
+/inputs  A N
+/outputs NAND
+/TABLE 2
+;A B NAND
+ L  H  L
+ X  X  H
+/endmodule
+/instance NAND_4060 MR RS ORTC
+/instance NAND_4060 MR ICTC CP
+/module NOT_4060
+/inputs  IN
+/outputs OUT
+/TABLE 2
+;IN OUT
+ L  H
+ H  L
+/endmodule
+/instance NOT_4060 IRTC OCTC
+/module CNTR_4060
+/inputs  MR CLK
+/outputs O3 O4 O5 O6 O7 O8 O9  O11 O12 O13
+/clock  CLK - 14 1 2
+;SYNC
+;MR CLK FFFFFFFFFFFFFF  O0  O1  O2  O3  O4  O5  O6  O7  O8  O9  O10  O11  O12  O13
+ X   X  XXXXXXXXXXXXXX F+0 F+1 F+2 F+3 F+4 F+5 F+6 F+7 F+8 F+9 F+10 F+11 F+12 F+13
+;ASYNC
+ L   X  XXXXXXXXXXXXXX  F0  F1  F2  F3  F4  F5  F6  F7  F8  F9  F10  F11  F12  F13
+ H   X  XXXXXXXXXXXXXX  L   L   L   L   L   L   L   L   L   L   L    L    L    L
+/TABLE 1
+;MR CLK FFFFFFFFFFFFFF  O3  O4  O5  O6  O7  O8  O9  O11 O12 O13
+ X   X  XXXXXXXXXXXXXX  F3  F4  F5  F6  F7  F8  F9  F11 F12 F13
+/endmodule
+/instance CNTR_4060 MR CP O3 O4 O5 O6 O7 O8 O9 O11 O12 O13
+/delay 20
+;input  output  Rise time  Fall time
+  RS      O3    100n        100n
+  RS      O4    112n        112n
+  RS      O5    124n        124n
+  RS      O6    136n        136n
+  RS      O7    148n        148n
+  RS      O8    160n        160n
+  RS      O9    172n        172n
+  RS      O11   196n        196n
+  RS      O12   208n        208n
+  RS      O13   220n        220n
+  MR      O3      X          60n
+  MR      O4      X          60n
+  MR      O5      X          60n
+  MR      O6      X          60n
+  MR      O7      X          60n
+  MR      O8      X          60n
+  MR      O9      X          60n
+  MR      O11     X          60n
+  MR      O12     X          60n
+  MR      O13     X          60n
+/constraint 3
+;   Name       Event From  Event To   Min/Max  Time
+ 'PULSE WIDTH'  LH    RS    HL   RS     MIN     30n
+ 'PULSE WIDTH'  LH    MR    HL   MR     MIN     20n
+ 'RECOVERY'     HL    MR    LH   RS     MIN     60n
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,186 Views)
Oops, I forgot to mention that this model is from my Multisim 2001 Database and it came with it. It is not something that I have created or downloaded.
Have a Nice Day
(4,185 Views)
