12-18-2015 11:26 AM - edited 12-18-2015 11:27 AM
this is what ive tried so far and cant get my way any further...and i tried implementing additional things too
12-21-2015 02:51 PM
Hello aak1703
I would like to know what is the main goal in that circuit? Just to see if I can recommend you something.
Regards
12-22-2015 02:42 AM
thanks for being so humble 😄
yeah..
1st of all..the circuit should have a transformer incorporated and a rectifier to convert aC to dC..which i can do..
2nd it should include a 24h timer which indicates thr hh mm ss..that is hour minutes and seconds in digital form using led display,thats the part that im stuck on...
the rest im being able to manage it quite well..
if you could give me the IC's and a schematic diagram would be of great help..thanks once again 🙂
12-23-2015 09:57 AM
Hello aak1703
I see. Yeah actually as you saw in the circuit that I made. That circuit can be modified just to use that for the minutes and after that the hours. Actually you can use that circuit for counting the seconds. Please review that and try to play with that.
Regards
12-23-2015 12:36 PM - edited 12-23-2015 12:36 PM
yeah..based on what you did i tried a circuit..however there are some issues which i cant figure out what is causing it..
some of the counters dont count till 9 to increment the other...could you help me fix it..that would be of great help..and can you tell me how you connet 2 circuits separately just like u did in you circuit..thanks
12-28-2015 11:44 AM
Hello aak1703
I attached the last example for you. Please use that as a reference. That would be pretty useful for you. Feel free to modify the circuit.
Regards
12-28-2015 12:28 PM
thanks...that was really helpful..
however..can u plz explain how do u connet the circuits to 1 another..koz im tryin it..but not being able..in words is fine,,,koz im trying the hour display..
thanks..the hours display aint changing when counter reaches 60 mins...
12-29-2015 01:47 PM
Hello aak1703
Actually you just need to create a count to 24 (hrs) for doing that you need to increment that count every time that you have 59 in minutes counter and 59 in seconds counter.
Regards
12-30-2015 12:11 AM
thanks david..
ive had already figure out how to do it...
ur example was of help... 😉
12-30-2015 01:50 PM
great 😃
For me was a pleasure working with you
Regards
