08-25-2007 04:52 PM
08-25-2007 05:26 PM
I don't know how you managed to get them to start with. I was told by Garret, a NI Tech Support Team Memeber, that only the Power Pro Version and EDU Version had all the tabs. The only thing I can think of is that you had access to the full version for a period of time as a trial and when that time expired it reverted back to the Base Version. This is conjecture on my part, but sounds reasonable. If that is the case, you probably won't be able to get them back.. I will post his exact words so you don't have just rely on what I tell you.
"What tabs you see in the spreadsheet depends on the particular version. Only PowerPro and Edu will see the Results, Nets, Components, and PCB Layers tabs. The Base, Full, and Student will see the Results tab."
I am sorry. I know this isn't what you would want hear. If anyone else has something different, then please post it.
08-27-2007 08:06 AM
08-27-2007 10:03 AM
