I used Multisim’s (ver 10) Monte Carlo Analysis I tried using an expression as the output variable
V(2)-V(5)
and got the message that the output vectors didn’t exist. When I use them individually it worked fine. I tried using the Copy Variable to Expression and Copy Function to Expression method, I tried the double click method, and the just type it in method with the same results each time.
Am I doing something wrong or is it broken?
