10-20-2008 05:39 PM
Hi, I am trying to amplify a 900MHz signal with multisim 8.
I have done some searches and I have not found any transistors or op-amps that will amplify this high frequency on multisim 8.
I have found 2 different Low Noise Amplifiers (LNA) on the net that could work.
I found a BFG480W and STB7001.
I have heard you can import new devices to your library.
Does anyone have these files and know how to add them in?
I looked and I do not see a "Library" folder.
01-26-2009 10:30 AM
Hi;
The way you can import a component into Multisim's database is based on a SPICE model, if you don't want to model the device yourself you can search in the manufacturer's page or the internet and you will probably find it. I attach a link to a tutorial that shows you how to create your own Multisim components.
http://zone.ni.com/devzone/cda/tut/p/id/3173
I hope the information is useful.
Good Luck |
