Multisim and Ultiboard
microphone and speaker doesn't work
Highlighted
NI LabView instrument doesn't work, the microphone and speaker, how can I troubleshoot this problem?
(2,286 Views)
Highlighted
Please make sure the LabVIEW run time engine of which the instrument was created is installed
Let me know if you have other questions.
Mahmoud W
(2,273 Views)
Highlighted
sir,
what is the particular NI LabView run-time engine version? On the national instrument software(product tab) I have two(2) NI LabView Run-Time Engine 7.0 & NI LabView Run-Time Engine 7.1.1
Do I have to remove the two(2) old version?
thanks!
(2,266 Views)
Highlighted
Go to the LabVIEW instruments installation folder under program files on your computer. For instance, if you use Multisim 11, it will be:
C:\Program Files\National Instruments\Circuit Design Suite 11.0\lvinstruments
Right click the microphone instrument LLB file and check which version of LabVIEW it is created with, this is the version of the LabVIEW RTE you should install.
If it still doesn't work, please check this article on how to properly install LabVIEW instruments
Mahmoud W
(2,258 Views)
Highlighted
sir,
suggestion are both done but still is doesn't work...I tried earlier to repair my installation of Multisim and still doesn't work.
Sir, can you give me a brief info of how does it works? how can I know that the mic can capture/record audio?
(2,227 Views)
Highlighted
anyone can help me here in dynamic phaser circuit, is Q7 and Q8 are the errors?(please open the attachment)...can I use a microphone and speaker here?...
rsdivine
(2,223 Views)
Highlighted
In Multisim, go to File>Open Sample and select the microphone and speaker design under the LabVIEW instruments folder.
This is a working designn, you can use it a s a starting point to troubleshoot your mic and speakers.
Mahmoud W
(2,201 Views)
