12-07-2012 01:10 PM - edited 12-07-2012 01:12 PM
When I installed evaluation version of multisim I got an error "unable to initialize DAO/Jet db".
I have found some solution in internet, but none is working (register, reinstallation). My operation system is Windows 8. I know also, that it is working for my friend (same system).
What could be reason of this? And how could I fix it?
Version of Multisim is 12.0.1.
I have also Microsoft Office 2013 (like my friend) if it could help.
12-10-2012 01:40 AM
I just want to check if you've tried this:
http://digital.ni.com/public.nsf/allkb/A0D4BDCD8ED6F2C5862571B800565831
It seems it was not tested on Windows 8 so far, so I suggest checking the path first, if it is the same as described in the KB. Thanks for testing!
12-21-2012 10:59 AM
First, sorry for my late answer.
Of course I tried this. It was one of first solutions I've found. But it didn't help.
After all I decided to reinstall my OS. And... It worked. I think that was problem of Windows 8. So if anybody would have same problem do not be surprised when you'll have to reinstall Windows.
03-19-2018 02:51 PM
Hey, I know that you have long since found the answer to your problem; but I was recently observing this same error every time that I tried to run my student/educator edition of Multisim version 14. I searched everywhere for an answer, I tried following the following procedure with no success:
I finally stumbled upon your post, which suggested reinstalling your OS. Anyways, long story short, I didn't want to go through that hassle so I kept trying things, and I found a solution for me that worked. Since I am getting this error 6 years later, I am sure others are too and I wanted to show an alternative solution for them if they experience this issue.
In my case, the databases were accessible when I opted to run Multisim or Ultiboard as ADMIN. This fixed this issue for me and made it work and able to access all the appropriate databases. I have to run it as admin every time, but I am under the impression that if you run the initial installation as admin this will fix the issue for good.
Good luck!
