Hello every one,
I've been working the MCU and LCD module in vesrion 10.
I cant to make it work. Your help will be really appriciated. we have purchased multisim at our school i need to prepare myself
to offer it. I seed to be stuck with a few things using the 8051, and LCD is one of them. If i get this right, then i will move to the next.
here is a code i got from another forum. I have tried different codes, but they all seem not to work. im not sure if it's the code or the design or some bugs with these modules. your help is most welcome.
here is the code:
#include <htc.h>
#include <stdio.h>
#define LCD_data P2
#define LCD_D7 P27
#define LCD_rs P10
#define LCD_rw P11
#define LCD_en P12
/*static volatile unsigned char LCD_data @ 0xA0;
static volatile bit LCD_D7 @ 0xA7;
static volatile bit LCD_rs @ 0x90;
static volatile bit LCD_rw @ 0x91;
static volatile bit LCD_en @ 0x92;*/
void LCD_init();
void LCD_busy();
void LCD_command(unsigned char );
void LCD_senddata(unsigned char );
void LCD_sendstring(unsigned char *);
void main()
unsigned char msg[] = "HELLO WORLD";
LCD_init();
LCD_command(0x80);
LCD_sendstring(msg);
while(1);
void LCD_init()
LCD_data = 0x38; //Function set: 2 Line, 8-bit, 5x7 dots
LCD_rs = 0; //Selected command register
LCD_rw = 0; //We are writing in data register
LCD_en = 1; //Enable H->L
LCD_en = 0;
LCD_busy(); //Wait for LCD to process the command
LCD_data = 0x0D; //Display on, Curson blinking command
LCD_en = 0;
LCD_data = 0x01; //Clear LCD
LCD_en = 0;
LCD_data = 0x06; //Entry mode, auto increment with no shift
LCD_busy();
void LCD_busy()
LCD_D7 = 1; //Make D7th bit of LCD as i/p
LCD_en = 1; //Make port pin as o/p
LCD_rw = 1; //We are reading
while(LCD_D7)
{ //read busy flag again and again till it becomes 0
LCD_en = 0; //Enable H->L
LCD_en = 1;
/*unsigned char i,j;
3+69
for(i=0;i<50;i++) //A simple for loop for delay
for(j=0;j<255;j++);*/
void LCD_command(unsigned char var)
LCD_data = var; //Function set: 2 Line, 8-bit, 5x7 dots
LCD_rw = 0; //We are writing in instruction register
LCD_en = 0;
/* Using the above function is really simple
var will carry the command for LCD
e.g.
LCD_command(0x01);*/
void LCD_senddata(unsigned char var)
LCD_rs = 1; //Selected data register
LCD_en = 0;
we will pass the character to display as argument to function
e.g.
LCD_senddata('A');*/
void LCD_sendstring(unsigned char *var)
while(*var) //till string ends
LCD_senddata(*var++); //send characters one by one
// we will pass the string directly to the function
// e.g.
// LCD_sendstring("LCD Tutorial");*/
Ihave also attached the schematic.
Tahnx in advance
