Multisim and Ultiboard
how to wire potentiometer
when you flip a potentiometer horizontally the software places the slider bar above the topmost node of the potentiometer -- this makes it difficult to connect (wire) unless you dramatically zoom in.  Seems that in the next set of bug-fixes the "locus" of the slider could be changed (set relative) so that you don't have to zoom to connect.  Link below demonstrates what I am seeing:
 http://www.tech-diy.com/Potentiometer_how_to.gif
(6,310 Views)
Hi Jackinnj;
If you move the percentage indicator to any other place near the component you can avoid having the slider over your connection, just as the attached image demonstrates.
Good Luck
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
(6,269 Views)
You're right -- the position of the slider does change -- seems that the change is activated when you click again on the schematic.
(6,260 Views)
