01-17-2009 10:00 PM
when you flip a potentiometer horizontally the software places the slider bar above the topmost node of the potentiometer -- this makes it difficult to connect (wire) unless you dramatically zoom in. Seems that in the next set of bug-fixes the "locus" of the slider could be changed (set relative) so that you don't have to zoom to connect. Link below demonstrates what I am seeing:
http://www.tech-diy.com/Potentiometer_how_to.gif
01-20-2009 04:09 PM
Hi Jackinnj;
If you move the percentage indicator to any other place near the component you can avoid having the slider over your connection, just as the attached image demonstrates.
Good Luck
01-20-2009 04:48 PM
